>If you were offended by my answer I am sorry
I don't think he took offense at your point (pun intended). I think he was saying that a drilled hole is generally not close tolerance - if a close tolerance on the diameter depth is required use an endmill (of course I have run into many engineers who don't know that a standard end mill is angled in from the outer edge to the center such that the bottom is actually slightly conic rather than planar - I've see that cause lots of confusion in inspection, especially on large diameter counterbored holes).
CAM software will take into account the drill point automatically without calculations when generating the CNC code. I remember many times back in the day when g-code was typed line-by-line the programmer might forget the point usually when rapid traveling from point to point leaving a scratch across the part. As for the manual operator - if he can't do the calculations hire someone else.
JD Mather
Certified Journeyman Machinist
8 yrs on the shop floor
