Unless I am misunderstanding (which is more than possible), the copy
components command does not address this issue.
I often work like this:-
1. I open a new assembly, place a few parts.
2. I open an existing assembly.
3. I copy some parts from the existing assembly to the new assembly. (any
constraints on the copied parts are lost).
4. I re-constrain copied parts.(this is the problem I think Mathias has and
one I also would like to be "remedied")
Wayne
"Rich Willis (Autodesk)" wrote in message
news:4833155@discussion.autodesk.com...
Matthias,
The Copy Components command should give you the results you are looking for.
"Matthias Julius" wrote in message
news:4833059@discussion.autodesk.com...
Here is another item of my personal wishlist:
When copying a bunch of components within an assembly that have a
couple constraints between them IV should copy the constraints as
well.
Example: When I have a component that is used several times in a
machine that component usually is bolted on to the machine. When I
copy the component and its fasteners to a new location it would be
very convenient when the fasteners would keep their constraints.
Also even if there are no constraints it would be nice if the copied
parts would have the same orientation as the original parts.
Matthias
