I need a pointer or two. I've got a basic understanding of inventor and can make basic drawings / assemblies and prints.
I've got a project that needs wire screen. A sort of chicken wire or square hole wire screen. What's the best way to approach something like this?
Seems to me that there has to be a "short cut" or easy way to make a panel with that format.
Any suggestions would be appreciated.
Thanks, Aj
Solved by JDMather. Go to Solution.
The best way would be to apply a texture color.
Check the Expanded Metal colors to start.
I think there might be additional textures at cbliss.com
This question comes up several times a week
http://forums.autodesk.com/t5/Autodesk-Inventor/Perforation-in-sheet-Metal/td-p/3308913
That makes easy work. I checked out the cbliss.coma and they have all kind of textures. Several l I'd like to try.
Is it hard to add the new files to the textures and colors of inventor? Looks like the files are .bmp.
Thanks for the guidance.
Aj
Manage>Styles and Standards editor.
Thanks for the help. You guys are fast. I did some checking and found a way. This was from another post from a while back. Even scaled it to make it fit the drawing better...
Great!! Thanks for all the help!!
Aj
Manage>Styles Editor>Material
select Aluminum and then click New Material. Name the new material as desired OK. Then delete the old material name (You might be able to rename directly - I didn't try it.
