Inventor General Discussion
Member
rajeshs07
Message 1 of 3 (305 Views)
Accepted Solution
Windows components failing/crashing due to Inventor
305 Views, 2 Replies
03-14-2014 06:29 PM
This question has already been asked here: http://forums.autodesk.com/t5/Inventor-General/Autodesk-Inventor-and-System-32-folder/td-p/3658424. But unfortunately there was no reply. So I hope Autodesk doesn't ignore it as it seems to be a serious problem. After I installed Inventor Professional 2014 (64-bit), various Microsoft components started failing/crashing; explorer will crash when navigating to System 32, windows MMC based applications always crash etc. After searching the web and going through my windows' Event Logs, I found these;
Error 1
Faulting application name: Explorer.EXE, version: 6.1.7601.17567, time stamp: 0x4d672ee4
Faulting module name: vtkFiltering.dll, version: 5.21.0.1, time stamp: 0x4e1d3238
Exception code: 0xc0000005
Fault offset: 0x00000000000ca21b
Faulting process id: 0x91c
Faulting application start time: 0x01cf3feb73531d9c
Faulting application path: C:\Windows\Explorer.EXE
Faulting module path: C:\Program Files\Autodesk\Inventor 2014\Moldflow\bin\vtkFiltering.dll
Report Id: b9d2ef16-abde-11e3-897f-0023ae803dd8
Error 2
Faulting application name: mmc.exe, version: 6.1.7600.16385, time stamp: 0x4a5bc808
Faulting process id: 0xfe0
Faulting application start time: 0x01cf3fe5a347e3c6
Faulting application path: C:\Windows\system32\mmc.exe
Report Id: e97d9de1-abd8-11e3-af55-0023ae803dd8
The commont pattern (which is obvious through google search results and looking at these error logs) is that the file "vtkFiltering.dll" is somehow causing components within the System32 folder to fail/crash/get courrupted or whatever you like to call it. Also for additional information, the computer is running a genuine activated copy of Windows 7 Professional (x64).
Member
rajeshs07
Message 2 of 3 (293 Views)
Re: Windows components failing/crashing due to Inventor
03-14-2014 07:09 PM in reply to: rajeshs07
Update
To confirm that it was the vtkFiltering.dll that was crashing these apps, I temporarily renamed it, and it worked. But now, there is a problem due to another dll also from Inventor. This time it is called AdSyncNamespace.dll.
Error 3
Faulting module name: AdSyncNamespace.dll, version: 4.6.12.800, time stamp: 0x51e5592a
Fault offset: 0x000000000001f5d6
Faulting process id: 0x12f4
Faulting application start time: 0x01cf3ff28f8b3385
Faulting module path: C:\Program Files\Autodesk\Autodesk Sync\AdSyncNamespace.dll
Report Id: 606e76af-abe6-11e3-941f-0023ae803dd8
Member
rajeshs07
Message 3 of 3 (283 Views)
03-14-2014 07:38 PM in reply to: rajeshs07
I managed to find out the problem. In the end, it was not Inventor, but the Autodesk 360 application that was causing all the havoc. After uninstalling 360, all the problems were fixed. While I managed to fix the porblems on my computer, I still think Autodesk should look into the problem with 360. I honestly have no idea what it is.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
