Inventor Forum
Windows 8 black screen
4 REPLIES 4
Maxcn
678 Views, 4 Replies
I am using Windows 8 with Inventor 2012 and have an issue with the Inventor windows going black only when I do a save. I am simply reporting this as I know Windows 7 is the recommended OS, even for Inventor 2013. However, it would be nice to know if there was a fix.  Nvidia apparently has no partner drivers for Windows 8 and I tried their Beta which didn’t help. I am running Intel’s i7-2700K with NVidia Quadro FX 3800. Thanks!
4 REPLIES 4
DarrenP
in reply to: Maxcn
no inventor version is supported on windows 8
does this happen on windows 7?
DarrenP
john.laidler
in reply to: Maxcn
I don't believe Inventor 2012 is supported on Windows 8.  You can try to run in 'compatibility mode', that may resolve your issue.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Maxcn
in reply to: john.laidler
To follow up I should explain that the black screen is a momentary occurrence; after I do a save all the windows flash to black and return to normal. It is just an annoyance. I have tried Windows 8 in compatibility mode, changed privilege levels and also changed the Inventor display quality settings to no avail.  I had no such troubles with Windows 7 but like 8 too much! Regards
stephengibson76
in reply to: Maxcn
same here, on AutoCAD also...  its something I am willing to live with for the win 8 overall computer speed improvement and amazing lightning quick remote desktop i use all the time
Stephen Gibson
View stephen gibson's profile on LinkedIn
