Inventor Forum
Win7 Registry Problem- icons, Context menu etc
3 REPLIES 3
robmatthews
601 Views, 3 Replies
G'day all.
With respect to the last post in http://forums.autodesk.com/t5/Autodesk-Inventor/Weld-bump-map-not-showing-amp-Visual-Styles-graphics..., it was mentioned "Unregistered Inventor and cleaned up the registry".
This process is interesting to me, as I have a slight problem that is registry-related, I think.  In Windows (7) Explorer, all my inv icons are the same (ipt, iam and idw), and i do not have Inventor-specific context menu when I right- click an inventor file. (ie no access to iProps, no Pack and Go, etc within WinExplorer.)
My machine has IV 2010 for production, and IV2014 for trials, stress analyses etc. I uninstalled IV2012 after installing 2014, and I think it was somewhere around this time that things went bad.
Does anyone agree with my thinking that a registy cleanup will fix things for me? If so, can someone step through the process for me please?
This is my signature, not part of my post.
3 REPLIES 3
tbs456
in reply to: robmatthews
I am having the same issue.  I updated to current service pack and BOOM; my icons got jacked.   Need some help!
-niels-
in reply to: tbs456
Several things you can try:
1. run as administrator (right-click on inventor icon)
2. go to C:\Program Files\Autodesk\Inventor 20xx\Bin and execute DtDv.exe
3. Change file association through windows configuration > standard programs
4. not sure if this helps, but topic has registry instructions: http://forums.autodesk.com/t5/Inventor-General/Inventor-2012-Icons-Windows-7-64/m-p/3189358/highligh...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
NathanLos
in reply to: tbs456
Hi tbs456,
You might have some luck with repairing the Inventor installation. Access it via Start > Control Panel > Programs [if Category mode is active] > Programs and Features > Autodesk Inventor 2014 > Repair.
In case that doesn't work, could you post a screenshot of the incorrect icons? It might give a clue as to what's causing the conflict.
Nathan
Autodesk Inventor Platform Team
Nathan Los
Principal Engineer
DLS-Mechanical Design
Tags (2)
