Inventor General Discussion
EdwardCChamberlain
Message 1 of 16 (352 Views)
Will my model break
352 Views, 15 Replies
11-12-2012 03:58 PM
I've created a model in inventor that is a plate with two pins coming off of it. (Made from ABS)
what i was wondering was weather there was a way to test wether the pin would snap when a force is aplied to it? I'm also interested in how much it will flex But it isn't essential.
how can I do this in inventor??
Thanks Ed. :smileyhappy:
Cadmanto
Message 2 of 16 (341 Views)
Re: Will my model break
11-12-2012 05:32 PM in reply to: EdwardCChamberlain
Ed,
You would have to do a stress analysis in Inventor.
What version of Inventor do you have?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
EdwardCChamberlain
Message 3 of 16 (295 Views)
11-13-2012 09:40 AM in reply to: Cadmanto
im using 2013, will have a look at that link. so far ive only managed to make it bend the part? :smileyfrustrated:
EdwardCChamberlain
Message 4 of 16 (291 Views)
11-13-2012 09:55 AM in reply to: Cadmanto
so as i understand if i see red anywhere in my simulation: It will break?
Ed.
JDMather
Message 5 of 16 (290 Views)
11-13-2012 09:55 AM in reply to: EdwardCChamberlain
Attach your file here.
Inventor does not do fracture analysis.
It will show you where part goes beyond elastic deformation into plastic deformation.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
EdwardCChamberlain
Message 6 of 16 (282 Views)
11-13-2012 10:16 AM in reply to: JDMather
Regretably i cant attach the actual design file but i will attach a demonstration piece when i get back to my computer.
So the plastic deformantion is a permenant change? Whereas elastic deformation is reversable? If so then i would require no plastic deformation.
Thanks Ed.
EdwardCChamberlain
Message 7 of 16 (242 Views)
11-13-2012 01:51 PM in reply to: EdwardCChamberlain
Ive attached a model. I want to apply pressure along the x and z axis to the top of the thinner rod. And then id want to know wether that rod would snap off.
Thanks Ed.
JDMather
Message 8 of 16 (239 Views)
11-13-2012 01:57 PM in reply to: EdwardCChamberlain
There is no material assigned.
Inventor doesn't do fracture analysis.
EdwardCChamberlain
Message 9 of 16 (222 Views)
11-13-2012 03:18 PM in reply to: JDMather
it should be assigned ABS plastic, and ok is there a way of finding out wether it will be irreverably dammaged?
JDMather
Message 10 of 16 (215 Views)
11-13-2012 04:07 PM in reply to: EdwardCChamberlain
Thanks Ed.
 Along the x and z where?  Equal in each direction?
