Inventor General Discussion
hhls11
Message 1 of 5 (292 Views)
Why does my derived part turn into a surface part?
292 Views, 4 Replies
11-12-2012 12:09 PM
I am deriving a part from an assembly. After I remove parts that I don't want included in the derived part, the part is automatically switching to a surface part. I was initially trying to use the hole and extrude functions and kept getting errors. I saw that the part was being made into a surface part. How can I fix this? Thanks in advance!
I'm running Autodesk Inventor Professional 2013.
Intel Xeon W3680 @ 3.33Ghz
12GB DDR3 RAM
NVIDIA Quadro 2000 GPU
Windows 7 Professinal 64-bit
JDMather
Message 2 of 5 (282 Views)
Re: Why does my derived part turn into a surface part?
11-12-2012 01:04 PM in reply to: hhls11
When you Derive Component there is an option to derive as Solid or Composite Surface.  I think the default is as Composite Surface body.  SImply edit and change.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
hhls11
Message 3 of 5 (274 Views)
11-12-2012 02:50 PM in reply to: JDMather
I've tried to edit the part, but composite surface wasn't selected. I had derived other parts before this one and they came out fine. It just seems to be this part. I never changed the setting either.
12GB DDR3 RAM
JDMather
Message 4 of 5 (269 Views)
11-12-2012 03:21 PM in reply to: hhls11
Attach the files here.
hhls11
Message 5 of 5 (231 Views)
11-14-2012 12:24 PM in reply to: JDMather
It turned out that a weld was causing the problem. Once I excluded the weld from my part, it worked fine.
12GB DDR3 RAM
