Inventor Forum
Why does my derived part turn into a surface part?
4 REPLIES 4
hhls11
451 Views, 4 Replies
I am deriving a part from an assembly. After I remove parts that I don't want included in the derived part, the part is automatically switching to a surface part. I was initially trying to use the hole and extrude functions and kept getting errors. I saw that the part was being made into a surface part. How can I fix this? Thanks in advance!
I'm running Autodesk Inventor Professional 2013.
Inventor Professional 2021
Intel Core i7-9700K @ 3.60Ghz
16GB DDR4 RAM
NVIDIA GeForce RTX 2060 Super GPU
Windows 10 Professional 64-bit
4 REPLIES 4
JDMather
in reply to: hhls11
When you Derive Component there is an option to derive as Solid or Composite Surface.  I think the default is as Composite Surface body.  SImply edit and change.
The CADWhisperer YouTube Channel
hhls11
in reply to: JDMather
I've tried to edit the part, but composite surface wasn't selected. I had derived other parts before this one and they came out fine. It just seems to be this part. I never changed the setting either.
16GB DDR4 RAM
JDMather
in reply to: hhls11
Attach the files here.
hhls11
It turned out that a weld was causing the problem. Once I excluded the weld from my part, it worked fine.
16GB DDR4 RAM
