HI,
when I was first presented inventor by our local reseler it was AI2009.
During standard prezentation I noticed that there was a bug in hole creation
Later I was informed by specialist that did the presentation that this bug was reported and will be fixed.
But for my biggest suprise I came across this issue in AI2013 when I was doing my design.
I enclose file that presents dicusted issue.
All holes schould go threw. And as you can see some are not 😉
Cris
Solved by -niels-. Go to Solution.
edit your pattern, select the >> sign in the bottom right, select "adjust" from the compute group.
That's what you want right?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
That option has been in Inventor for a long time-- I think the specialist who demonstrated Inventor 2009 for you didn't know about it, and instead called it a bug.
