Inventor Forum
Where to show dimension names
10 REPLIES 10
Message 1 of 11
Karol-Or
6518 Views, 10 Replies
In a sketch in a part i want options to show dimension names etc', i don't find it in the document settings, nor in the application settings, nor when i right click a dimension
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: Karol-Or
Must be in sketch editing mode.
Right click in the graphics window and select desired dimension display mode.
Message 3 of 11
CCarreiras
Hi!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 4 of 11
Greatwhitenorth
Click the middle icon along the bottom.
____________________________________________________
Product Design & Manufacturing Collection 2021 | Vault Professional 2021
Dell Precision 7670 | Intel i7-12850HX - 2100 Mhz - 64GB
nVIDIA RTX A3000 12GB | Windows 10/64 Pro
Message 5 of 11
Looks like this has been changed at some point. I was trying to do the same thing in v2018 and finally found the option under document settings; units; "display as expression".
Inventor Professional 2020
HP Z440, Xeon E5-1650 @ 3.6GHz
32GB Ram
GTX 1080
Windows 10
Message 6 of 11
No difference.
or
Message 7 of 11
I see the option as shown your first image now on the bottom of the screen, v2018 doesn't seem to have the option as shown in your second image.
32GB Ram
GTX 1080
Windows 10
Message 8 of 11
@jeffsteiger6735wrote:
... v2018 doesn't seem to have the option as shown in your second image.
The image is from Inventor 2018.
Are you in an active sketch?
Are other tools active?
Message 9 of 11
Weird. Started a brand new sketch, don't see that option. Image attached.
32GB Ram
GTX 1080
Windows 10
Message 10 of 11
You are right clicking on the Sketch node in the browser.
Instead, right click away from everything in the graphics window.
These right click options are context sensitive depending on where you click.
Message 11 of 11
Ahah!  Thanks.
32GB Ram
GTX 1080
Windows 10
