I want to find out if Update1 is installed already, but I can't find the about button, like in Autocad.
Danny
Solved by blair. Go to Solution.
Click on the little drop down arrow next to the question mark on the upper right corner of the inventor window.
Jeff showed you where to find the About information in Inventor, but this will not tell you if Update 1 has been installed or not. For that you have to go to Control Panel > Add or Remove Programs (Windows XP-- I don't recall what it's called in Windows 7) and be sure the Show updates box is checked.
Oké
Thanks both, but I haven't found it yet..
I will update my Inventor and look again, after that I will let you know what's the exact solution...
Danny
You need to go: Start>Control Panel>Programs and Features>View Installed Updates:
It's been this ways since Vista.
Hi Blair,
Now i found that the update for Inverntor is not insytalled, but fot Autocad and other programms it was.
Thanks all for your time!
Danny
