Inventor General Discussion
Distinguished Contributor
Karol-Or
Message 1 of 2 (312 Views)
What does the locked sign in a dimension mean
312 Views, 1 Replies
01-17-2014 10:39 AM
i made a hole with placement linear. what does the lock sign mean? i can change the value of the dimension in either case, locked or unlocked
JDMather
Message 2 of 2 (306 Views)
Re: What does the locked sign in a dimension mean
01-17-2014 10:57 AM in reply to: Karol-Or
You can click on the "gobe" in the center of the hole and drag the hole to approximate location.
If you lock one of the dimensions and try to drag - it will only allow dragging along the remaining degree of freedom, if you don't lock, you can drag in x and y.
This only stays in effect while editing.  As soon as you accept (OK) the locks are removed.
You can always replace dimensions, this only effects the dragging of placement.
BTW - I didn't know any of this before answering this question.  I determined this behavior by experimentation and observation when you asked the question.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
