Inventor Forum
Weldment
2 REPLIES 2
dcmorgan
296 Views, 2 Replies
Weldment
I am creating an assembly, and I just converted it over to the weldment environment where I will be placing 8 welds on a ring. Before I can place the welds on there, it asks me to specify the weld bead material. I set it at Welded Mild Steel. I want to eventually save out the entire assembly and replace the components with stainless steel parts. My question is can I can now go back and change the welded material to "stainless steel"?? How can you get material to show up on the welded symbol?
Edited by
Discussion_Admin
2 REPLIES 2
GSE_Dan_A
in reply to: dcmorgan
To change Weld Material simply right click on the Welds Folder in the Assembly Tree --> iProperties-->Physical Tab and then under the Material heading use the Pull Down Tab to select material.
GSE Consultants Inc.
Windsor, ON. Canada
dcmorgan
in reply to: GSE_Dan_A
THANKS A LOT...I GOT IT.
