Inventor Forum
Weldment problem
9 REPLIES 9
Message 1 of 10
arto.ww
843 Views, 9 Replies
Weldment problem
How can I make a weldment in these kind of situtation? Arrow is pointing where I want weldment to be.
There's cut in circle part and other part is filling that to half way. How can I fill that with weld?
9 REPLIES 9
Message 2 of 10
blair
in reply to: arto.ww
When you see a "Cross-Part" error, this usually points to "Adaptively". When you clear (un-check) the Adaptively on the parts, the welds in the "slots" can be made.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 10
JDMather
This assembly is designed incorrectly.
A 20mm hole will not have any material for threads.
And a 20x8 box will not fit into a 20x8 hole (unless the parts are made to very tight tolerance and press fit).
Message 4 of 10
arto.ww
Blair: That did the trick. Thanks!
Now I can make fillet welds around the slot. Is it possible to fill that slot with one weld? If you know what I mean.
JDMather: Yes it might be incorrect, I'm just learning. I thought that when I put thread in same size extruded hole would be correct way. Perhaps it would be easier to use Hole command with thread option.
Message 5 of 10
blair
Select the"Base surface for your #1, then select the four sides for your #2. You will then get all four sides under one fillet.
Delta Tau Chi ΔΤΧ
Message 6 of 10
arto.ww
in reply to: blair
Yes I did that, but I don't mean that now. I mean is there a possiblity to make one single weld, one bigger weld which is edge to edge in that slot.
Message 7 of 10
blair
Look at "Groove Weld"
Delta Tau Chi ΔΤΧ
Message 8 of 10
arto.ww
in reply to: blair
Yes that works. I tried it before but I chose faces from different parts, that didn't fill the slot. Now I chose faces from same part (circle), opposite sides of slot. That filled the slot entirely.
But if I do a stress analysis to this weldment, it would be better to put fillet welds around slot faces?
Message 9 of 10
blair
Most of my FEA work is done in Mechanical Simulation. I'm not sure how the FEA within IV would treat the zero-gap items and how it reads/treats welds.
Delta Tau Chi ΔΤΧ
Message 10 of 10
arto.ww
in reply to: blair
I don't need that FEA, just a question what came in my mind.
Thanks for your answers!
