Hi all
I am wondering can somebody help me out with this issue. I have a solid bar which has a diameter equal to the nternal dimensions of a SHS. I am trying to create a weld, basically to fill the gap with a weld. I tried a similar arrangement with a Circular Hollow Section and it worked perfectly. I have tried fillet and groove for the SHS but it will not accept it.
Any suggestions?
Thanks in advance
Padraig
Solved by blair. Go to Solution.
I had to use 2 groove welds to fill the gap between the ID of the tup and the shaft, I selected the two corners and the side and used the direction towards the other side, then did the same with the oposite side to produce a smooth top surface, then the corner fillet weld. Also it was showing a fillet with a bead of 20mm. A little to big to this end.
