A coworker brought this to my attention and I was also immediately able to reproduce this. We use content center C channels and other common beams a lot. After inserting one into an assembly if you right click and select change size and edit the length it typically doesn't update to the correct length.
Example:
Insert a 10" Ansi MC/C channel any size
add +.0625 to the existing length and hit apply
measure it at 10.06252 in
repeat change size and type in 10.0625
repeat change size and type in 10 + .0625
and measure at 10.06252 in
It seems to mess up more when you do math but it also screws up entering a simple number
10.000325 usually ends up as 10.000315 in for me.
Does this happen for anyone else?
P.S.
Editing the part directly from it's parameter dialog doesn't yield anything like this.
I'm able to reproduce this as well. The issue seems to occur using fractional amounts with more decimals to compute. For example, adding 10+.5 works just fine. 10.5+.03125 gives me 10.53126. Not off by much, but why would it be off at all?
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator; Vault Professional 2013
Win 7 x64, Dell Precision PWS690, GeForce GTX580
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for trying this out. I guess I'll go file a formal bug report since they get looked at more than the forums.
common mistake among people here,
These forums are not for discussing with or contacting Autodesk about any issues with the software. Autodesk provided these forums for end users like you and I to converse and solve problems.
I realize that. I was purposely asking others if they experienced the same issue as some times a few computers at the same work place isn't really a good sample size. If others had the problem I'd move on to filing a bug report, which I have.
I get it simply by entering a length of, say, 10.5625. It comes out almost invariably as 10.56252. No math involved in that one.
Rusty
Frame Generator is great, but it has bugs. You are better off deleting the FG member and replacing it rather than changing it. I have been caught out numerous times because doing a change can leave the previous members part number in the iProperty, thereby stuffing up the BOM. Again, DELETE rather than CHANGE.
I'm not even using the Frame Generator, just inserting content center parts. Also wouldn't double checking iprops be a smart thing to do any time you update a part?
Also would you rather delete a channel with 20 or so contraints and redo all of that or just edit the length and check the iprops afterwards?
Sorry, jumped the gun a bit there! I hardly ever place from CC. Frames are my thing where I delete and replace.
I think changing the iProperties can lead to errors. It's manual work that you must remember to do but is often forgotten. I prefer to use the intelligence in the software. It's much better with numbers than I am. The constraits depend on how you have done them in the first place.
