Hello Anne,
I realize that this question is not your responsibility but if you know the
answer it will save me some time.
I know (as this thread states by you) how to Tools>Options> Security Tab ...
uncheck "Do not allow attachments to be saved or opened that could
potentially be
a virus." How do I turn this like option off in Outlook? I can't find it.
Thanks if you can,
Keith Bradford
"Anne Brown" wrote in message
news:3F2187AB.50465F60@autodesk.com...
> Lloyd -
> Try this as it works for some who have difficulty seeing
> attachments on the HTTP side. To see a file from the web-based
> interface, go to the thread, and, instead of scrolling down to
> the post, go to the "Message Thread" Pane and click on the
> poster's name. The lower pane will reset itself at the top of the
> post, and you should be able to download the file.
> or
> Two things Under Tools>Options> Security Tab ... uncheck "Do not
> allow attachments to be saved or opened that could potentially be
> a virus."
> And when you are using the Web, be sure to click on the name in
> the top right before clicking on the attachment in the lower
> right.
> or
> First Left Click on the message in the upper right pane. After it
> reloads the thread, you can Right Click and "save target as" or
> Left Click and it should prompt for a save location.
> or
> If you are accessing the newsgroups from the web-based [HTTP]
> interface, in order to have access to an attached file in any
> post but the first post, you need to find the right
> name/date/time in the "Message Thread" pane, directly above this
> pane. Click on the name, and that will cause the selected message
> to appear here. You will then be able to download/view the
> attachment,
> Anne Brown
> Manager, Moderator
> Autodesk Product Support Discussion Groups
> Discussion Q&A: http://www.autodesk.com/discussion
> LloydM wrote:
> > oops.
> > why is it that I can't see some of the things people post in
> > this newsgroup?
> > have read a few posts that say look at this, and some replies
> > can see it while others can't.
> > I'm sure this post will get moved elsewhere but I only know the
> > address for this group.
> > thanks, Lloyd
