Inventor Forum
WELD CALCULATOR
6 REPLIES 6
methoni
833 Views, 6 Replies
WELD CALCULATOR
 Using the weld calculator in inventor 14 is it possible to create a report similar to the fea analysis.At the moment after the initial calculation has been done
any output does seem to dissapear to some obscure folder.
Regards
6 REPLIES 6
blair
in reply to: methoni
By default the Weld Calculator with publish the report to the following: Your Drive Letter and Work Path, it will then add a folder for the Assembly Name with a sub folder "Design Accelerator" with a file name of "Fillet Weld (Connection Plane Load)1.iam". You can find the path name and location selecting the little Hand on Paper icon at the upper RH corner of the Fillet Weld Calculator.
Delta Tau Chi ΔΤΧ
Curtis_Waguespack
Hi methoni,
When you click the Results button, you get the report in an *.htm file, you can then sprint that as a PDF file if you have CutePDF or something similar installed? Other than that I don't know of anything other than what blair suggests.
I hope this helps.
Curtis
methoni
in reply to: Curtis_Waguespack
Thanks Curtis
I will give that a try, its always good to have something tangible to look at.
Regards
methoni
in reply to: blair
Thanks Blair
The little hand on paper icon sounds like  the secret, i will give it a try.
Regards
methoni
in reply to: blair
Hello Blair
Tried your approach and that works but also noticed that little box to the right ,clicked on that and that gives me the results read out,this is what i was looking for as the saying goes " could,nt see the wood for the trees"
Regards
blair
Sometimes that happens to everybody. 🙂
Delta Tau Chi ΔΤΧ
