Inventor Forum
Volume calculation
12 REPLIES 12
Message 1 of 13
Jefkee
1543 Views, 12 Replies
Volume calculation
I made some kind of "bucket" for molten metal and i want to know what volume it can hold. So i made the inside of the "bucket" and then get the volume from the physical properties. It worked great.
Now they asked me can you give us the volume of each centimeter of the bucket. What i would do is cut a centimeter out of the shape and get the volume. Again it worked great; the only problem is that i would be forced to do this for +1000 times to get all the volumes (its a big bucket).
Is there a way for me to get my cut out to go up each time with a centimeter and then export for each level the physical properties to excel. Making a list with all the calcutated volumes
Thanks, i really hope that there is a way! if there are any questions just ask!
In attachement a image of the bucket inside
Inventor 2013
12 REPLIES 12
Message 2 of 13
stephengibson76
in reply to: Jefkee
have a look at this part... rule2 drives the popup but it is always step behind because it doesnt update until after its displayed the value.
go to your parameters and change the parameter 'zero' plus or minus 1
it doesnt output how you want but im no expert and just had a little lunchtime play, im sure its possible and possible to update realtime
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 3 of 13
Jefkee
in reply to: stephengibson76
Ok, i looked at it, and seems good! I went further on it, and came up with this, but as you say, it is a step behind!
I made these parameters and this rule
iLogicVb.UpdateWhenDone = True
Row_Value = Height_Measurement / 10
row = CStr("A") & Row_Value
volume = iProperties.Volume
GoExcel.CellValue("C:\VaultWorkspace\cadcampc\12853\drawings\test.xls", "Blad1", row) = volume
**The height_measurement is against my ref point and always be +1
So what i still need it to do, is make a loop.
   - Start Loop: height_measurement = 1
       - Write volume value to cell "A1"  --> should be set by row declaration
   - Loop: height_measurement = 2 (1 + 1)
       - Write volume value to cell "A2"  --> should be set by row declaration
   - Loop End should be when volume value = 0
       - Message box : Measurements are done
Inventor 2013
Message 4 of 13
stephengibson76
in reply to: Jefkee
I created a new rule 'rule3' which is this
iLogicVb.RunRule("rule2")
then deleted the 'updateWhenDone' from rule2 and placed the line
iLogicVb.RunRule("rule3")
at the top of rule2
this is a rather ineloquent way of forcing it to update to the parameter entered, there will be a better way by someone more experienced
I would be interested in your finished rule to workout displacment of ships hulls at different waterlines and am willing to help where i can
Stephen Gibson
Message 5 of 13
Jefkee
 Hi, again..
I tried some things but I still cannot get things to work, something is wrong to my code, it seems that my loop works but my write to excel doesn't.
First lets have a look at the code:
InventorVb.DocumentUpdate(True)
Dim row As String
Dim volume As Double
rowvalue = 0
While Height_Measurement <= Max_Height
	Height_Measurement = Height_Measurement + 10
	rowvalue = rowvalue + 1
	InventorVb.DocumentUpdate()
	row = CStr("A") & rowvalue
	MessageBox.Show("height = " & Height_Measurement & " row = " & row & " volume = " & volume, "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	GoExcel.Open("C:\VaultWorkspace\cadcampc\12853\drawings\test.xls", "Blad1")
	GoExcel.Save
	GoExcel.Close
If Height_Measurement > Max_Height Then
	MessageBox.Show("Excel sheet ready", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Exit While
End If
End While
I made a message box that reports back to me what values are active (for testing) and there the output is almost ok. It shows that it gives a loop where the height_measurement and rowvalue is changing as I want. The volume on the other hand stays the same trough out the loop. This is because my 3D model doesn't update in the loop, and I don't know how to get it to do so.
Further my expectation would be that it in my excel-sheet I would get a list of the same volume values. But here it only shows in the first cell.
Anybody got any idea how to get it to write in all the cells that are needed and update my 3D model during my rule loop?
Thanks.
Inventor 2013
Message 6 of 13
stephengibson76
in reply to: Jefkee
can you post your part as well?  this thread might get better results in the customization forum
Stephen Gibson
Message 7 of 13
Jefkee
here is my part.
 Its the test rule that is supressed, the other rules are other tryings but not as good (but working) you have to end inventor to exit the cyclus 😕
Inventor 2013
Message 8 of 13
VdVeek
in reply to: Jefkee
Jefkee, I tested this a little bit and i found the command: RuleParametersOutput() under the Document-Snippets.
When i place that line before the DocumentUpdate i get some good results. I need to test it some more before i post some code, but you can give it a try.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 9 of 13
VdVeek
in reply to: VdVeek
I saw you have inventor 2012, I use 2013 at the moment so i just place the code here that works for me.
It creates a textfile but you can also write the information to an excel-file.
First i set the Hoogte Split propertie to 0mm, and then run the rule. There will be a textfile in the same folder as the part with the volumes in it.
Hopes you understand the code.
Rob.
Message 10 of 13
Jefkee
in reply to: VdVeek
edit,
i need to change that! i use 2013 now too 🙂 and its needed in excel but i will have a look later! thanks!
Inventor 2013
Message 11 of 13
Jefkee
in reply to: Jefkee
I will post a 'clean' code of my version that writes to excel later today. But ive got it working thanks! Bedankt!
Inventor 2013
Message 12 of 13
stephengibson76
in reply to: Jefkee
Hi, did you ever manage to get this working?  I would love a copy of the code
thanks
Stephen Gibson
Message 13 of 13
stephengibson76
in reply to: VdVeek
this worked for me...  Ive adapted it to drop into an assembly so you can simply place any ship hull into the assembly, run the rule and pump out the gross tonnage for different waterlines...  a very useful tool
Stephen Gibson
