I have an iPart which has a custom axis in a certain direction. I need this axis for my program, but I don't want it to be visible to the user.
When I was developing the program the axis was visible so that I could debug. But now I want to make the axis invisible, but I've found that I apparently need to select each iPart factory member and manually set the visibility to off (in each member). But this is not a column in the table of the iPart, so why doesn't setting it off at the highers level in the browser set it to off in all the members?
In the factory table, did you try looking under the suppression tab for the axis? So you can suppress the axis as needed for each member.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Is suppression the same as invisibility?The axis is geometry rather than a feature...
I'm not at that computer at the moment, but I'll give it a try later...
Kinda sort of. Suppression removes the item from site as well as memory where as visibility just removes it from site.
I apologize. When I first posted I was going on memory and have since tried out what I was trying to explain. While the axis does show up in the ipart member table, it does not allow suppression of axis. Infact axis cannot be suppressed at all. So visibility is the only option. With that said, I know there are hotkeys that toggle the planes and axis on/off. It appears what you are trying to do is a bit more complex then that. So I am wondering if an iLogic routine would work better for you.
