Greetings,
Has anyone else had the problem where a part in an .ipn explosion can be toggled invisible but then can't be made visible again. I am on Inventor 2012Pro.
Randy
Solved by johnsonshiue. Go to Solution.
Ok, getting desperate now. I really don't want to have to recreate the entire drawing and presentation file because I inadvertently turned 1 component visibility off.
Am I the only one who has noticed this behavior. I have tried it on a different test file and the behavior persists.
Randy
Hi! This is a recently known issue in R2012, which has been corrected in the internal build. Somehow certain UI elements are not interacting properly under specific conditions. The quickest way to change the behavior is doing the following.
In Inventor, go to View tab -> User Interface -> uncheck Marking Menu.
Let me know if it works.
Thanks!
