I hope you all can give me some insights as to why this is happening.
I am using valves as drain lines and it looks good in my isometric but when I attach the view to the sheet the handles get cut off.
Weird.
Thank you for your help!!
Angela
Solved by mcgyvr. Go to Solution.
Any chance they are Reference parts in the assy BOM? There are special controls for these type of parts and if they aren't set (on the Drawing View) they can get cut off.
I do believe that the handle is a reference part. Does that make a difference? I am relatively new to Inventor. How would I create a side view?
Thank you 🙂
Angela
Thank you 🙂
Angela
Bingo... yes it makes a difference.
Edit the view and go to the second tab (model state) and make the "margin" larger. (right under the hidden line calculation section)
Exactly right! If any part is Reference in BOM, then they are cut off from drawing views.
