Hi all
Info:
I used to use "Level of detail" to hide components etc for detailing purposes, thanks to the forum, I now use "Representations"
Amongs a few customised views, I have a set search for fastners.
Question:
Is there a way to automate the search (Saved search) and then switch off the visibilty of the items?
Preferably some iLogic code?
I have to run the search quite a few times during the design/detailing process, and sometimes things slip through the cracks, esp when I change fastners. (Note, All the fastners are extracted from the CC and saved with a new name and details.) It would be great to just run a rule.
Thanks.
Solved by Curtis_Waguespack. Go to Solution.
Hi rhasell,
Here is a rule that will create a view rep and turn off the visibility of components based upon a Custom iProperty value.
I hope this helps.
Curtis
'define View Rep name Dim oNewVRep as Object oNewVRep = "Fasteners Off" 'define custom iProp value to look for Dim oComparator as Object oComparator = "Bolt" ' set a reference to the assembly component definintion. ' This assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oViewRep As DesignViewRepresentation 'Look for an existing View Rep of the same name and delete it if found For Each oViewRep in oAsmCompDef.RepresentationsManager.DesignViewRepresentations If oViewRep.Name = "Master" Then 'set the Master View Rep to be active oViewRep.Activate 'if Master is already active, skip error On error Resume Next 'look for same name view rep Else if oViewRep.Name = oNewVRep Then 'delete same name view rep if found oViewRep.Delete Else End if Next 'create new View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(oNewVRep) 'define current document Dim openDoc As Document openDoc = ThisDoc.Document 'look at all of the components in the assembly Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition 'define the first level components collection Dim oCompOcc As Inventor.ComponentOccurrence 'define the next level components collection Dim oSubCompOcc As Inventor.ComponentOccurrence 'Turn off the visibility of parts in the top level assembly that include a 'custom iProp designating them as fasteners For each oCompOcc in oCompDef.Occurrences 'set visible if custom iProp does not match comparator value If iProperties.Value(oCompOcc.name, "Custom", "TYPE") <> oComparator Then 'Turn the visibility on oCompOcc.Visible = True Else 'Turn the visibility off oCompOcc.Visible = False End If 'Turn off the visibility of parts in the second level assembly that include a 'custom iProp designating them as fasteners For Each oSubCompOcc In oCompOcc.SubOccurrences 'set visible if custom iProp does not match comparator value If iProperties.Value(oSubCompOcc.name, "Custom", "TYPE") <> oComparator Then 'Turn the visibility on oSubCompOcc.Visible = True Else 'Turn the visibility off oSubCompOcc.Visible = False End If Next Next
Thanks so much for the prompt response.
I have one more addition,
I have applied a "Custom", "TYPE" setting to all my components, (The reason for this is sorting the BOM in a sequential order.)
eg
Bolts = "BOLT"
Nut = "NUT"
Washer = "WASHER"
Extrsusion = "XTR"
Tubes = "CHS"
etc.
Can I add the additional oComparitor of "NUT" and "WASHER" to the list?
I played around a bit with the code, but you have a far superior knowledge of the process, I am a noob when it comes to iLogic.
Thank you.
Hi
I am trying to attach a test assembly, but it keeps on timing out (720k)?
I noticied that is does not run in the sub assemblies.
Hi rhasell,
Here is an updated version.
I hope this helps.
Curtis
'create comparator list oStringArray = new string(){"Bolts", "Nuts", "Washers", "Extrusions", "Tubes"} 'get input from user oList = InputListBox("Select a type", oStringArray, "Bolts", "iLogic", "Available Types") 'define custom iProp value to look for Dim oComparator as Object If oList = "Bolts" Then oComparator = "BOLT" Else if oList = "Nuts" Then oComparator = "NUT" Else if oList = "Washers" Then oComparator = "WASHER" Else if oList = "Extrusion" Then oComparator = "XTR" Else if oList = "Tubes" Then oComparator = "CHS" Else End if 'set a reference to the assembly component definintion. 'This assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'define view rep Dim oViewRep As DesignViewRepresentation 'define view rep to use Dim sVRep as String sVRep = "Fasteners Off" 'define an arraylist to hold the list of view rep names Dim NameList As New ArrayList() 'Look at the view reps in the assembly For Each oViewRep in oAsmCompDef.RepresentationsManager.DesignViewRepresentations 'set the list of names to the array list NameList.add(oViewRep.Name) Next 'check to see if the arraylist contains the desired view rep If Not NameList.Contains(sVRep) Then 'create new View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep) oViewRep.Activate Else if NameList.Contains(sVRep) Then 'set existing view rep active oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep) oViewRep.Activate End If 'define current document Dim openDoc As Document openDoc = ThisDoc.Document 'look at all of the components in the assembly Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition 'define the first level components collection Dim oCompOcc As Inventor.ComponentOccurrence 'define the next level components collection Dim oSubCompOcc As Inventor.ComponentOccurrence 'Turn off the visibility of parts in the top level assembly that include a 'custom iProp designating them as fasteners For each oCompOcc in oCompDef.Occurrences Try 'set visible if custom iProp does not match comparator value If iProperties.Value(oCompOcc.name, "Custom", "TYPE") <> oComparator Then 'do nothing Else 'Turn the visibility off oCompOcc.Visible = False End If Catch 'assume error means iProperty not found End Try 'Turn off the visibility of parts in the second level assembly that include a 'custom iProp designating them as fasteners For Each oSubCompOcc In oCompOcc.SubOccurrences Try 'set visible if custom iProp does not match comparator value If iProperties.Value(oSubCompOcc.name, "Custom", "TYPE") <> oComparator Then 'do nothing Else 'Turn the visibility off oSubCompOcc.Visible = False End If Catch 'assume error means iProperty not found End Try Next Next
Thanks for your help mate.
Hi rhasell,
You might be interested in this new app on the exchange apps store - it automatically maintains view representations (for use in drawing views and parts lists) based on up to 2 custom or standard iproperties. You can create and manage as many of these 'saved filters' as you like, and save them in a template also.
App:
Video:
Best regards,
Luke
