I'm working in ancient Inventor 2009 and I'm using view representations for all of my .ipn levels. I've accidentally skipped one step and would like to put it in the middle of the others. Is there a way to re-organize the representations. I've attached a picture. I need to insert a representation above the check marked one.
Solved by mcgyvr. Go to Solution.
If you can't drag it either Up of Down then you are pretty much stuck with it. I don't think anyone has written any iLogic to sort the View-Reps
yes (in that you can) and no (in that its not as simple as it clearly should be)..
Lets say you have these view reps
1
2
4
What you have to do is create your new view rep (view rep 3).. It will now be at the bottom of the list.. So now you will have
1
2
4
3
Now copy 4 (and give it a temp name) and it will be below 3 now.. Then delete the original 4.
Its STUPID yes.. Many users have been requesting this feature for years but to date we still must do the "copy/paste dance"
