Just was upgraded to Windows 7 Professional 64Bit and I currently have an NVIDIA Quadro FX580 video card. The card worked great when I was running Windows XP 32bit and Inventor 2008 but now I am experiencing very slow transitions when moving an assembly or dragging a view in a .IDW. I am also experiencing issues with google image searches and some other misc. I was wondering if the video card I have is fine or is there something else I should be looking at?
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA Quadro FX 580
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 4_1
Quality Mode
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 8.17.12.6570
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 190, Release: 2012 SP1 - Date: Mon 08/08/2011
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Routed Systems: Tube & Pipe
Inventor Fusion Change Manager
Fusion Freeform Edit Launcher
Mold Design
Inventor Studio
Design Accelerator
Frame Generator
BIM Exchange
Routed Systems: Cable & Harness
Drag & Drop Interoperability
Simulation: Stress Analysis
System Information:
Operating System: 64-bit Microsoft Windows 7 Professional (Build 7601) Service Pack 1
Language: English
System Manufacturer: INTEL_
System Model: WBIBX10J
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz (1 processor, 4 cores, Hyperthreading enabled)
System Memory: 7.991 GB RAM
Graphics Device Information:
Renderer: HAL
Manufacturer: NVIDIA
Chip Type: Quadro FX 580
DAC Type: Integrated RAMDAC
Graphics HW Memory: 512 MB
Display Mode: 1920 x 1080 (32 bit) (60 Hz)
Graphics driver file: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver file version: 8.17.12.6570
Driver Date: 9 November 2010 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: NVIDIA Quadro FX 580
Vendor ID string: 0x000010de
Device ID string: 0x00000659
VendorID: 10de
DeviceID: 659
SubSystemID: 63a10de
Revision: a1
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 488 MB
Dedicated System Memory: 0 MB
Shared System Memory: 3.500 GB
DxDiag System Information:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
Processor: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz (8 CPUs), ~2.8GHz
System Memory: 8192MB RAM
Page File: 2128MB used, 14234MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version: 10.0
DDI Version: 10
DDI Version Number: a
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Revision:
Graphics HW Memory: 4071 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
Driver file version: 8.17.0012.6570
Driver Date: 12/23/2010 06:08:45
WHQL Level: 1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
The card and driver you have are both listed as Certified for Inventor 2012. What you may be experiencing is due to a chance made in the graphics that was introduced in Inventor 2011. You also are using a different DirectX version in Win7 than you were XP so that is something to consider. Win 7 and Vista are also more graphically demanding than Xp was.
You could try to change your Video Options from Performance or Quality to Compatibility mode which will make it comparable to older Inventor versions to see if the performance is more familiar.
I hope this helps.
Does the compatibilty mode affect new assemblies/drawings? I'm only experiencing this with new assemblies.
I'd just upgrade to the latest driver version on nvidias site (275.89 released 08/12/2011) and move on...
