Inventor General Discussion
New Member
lukea125
Message 1 of 2 (115 Views)
Vehicle Seat Frame Simulation
115 Views, 1 Replies
01-29-2014 06:32 PM
I was wondering if anyone would have any advice relating to an issue I'm having with an Inventor 2012 stress simulation.  I am working on a seat for a truck and am currently attempting to simulate a crash, to check the strength of the seatbelt anchorages.  As you can see in the attached picture, a 3 point belt is to be used, attaching to an upper bolted anchroage and two lower, bolted anchorages.  The only information I have related to testing conditions is that a force of 6750N is to be applied too two traction devices, that simualte the belt straps.  I'm having some issues recreating these conditions in the inventor simulation environment.  The main issue I am having is accurately recreating the force conditons at all 3 anchorages, namely the direction and the points at which the force is applied.  Using the forces I currently am, I am obtaining what appears to be a number of stress singularities (stresses of around 3000MPa) which I think may be a result of the force conditions I am using.  Any information on an easy way to achieve semi-relevant simulation conditions would be appreciated.
Thanks!
*Expert Elite*
JDMather
Message 2 of 2 (73 Views)
Re: Vehicle Seat Frame Simulation
01-30-2014 03:43 AM in reply to: lukea125
Can you attach the Inventor file(s) here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
