I used the workspace sync the other day for the first time and now everytime I open something new in Inventor I get this warning saying "unavailable project location". I hit ok and all is well. What is going on? I don't understand, if everything is fine, why the warning. I have attached a screen shot of the warning.
Solved by coreyparks. Go to Solution.
When you run that sync can you have it remove empty directories in your project path? If that is so I would guess all you need to do is recreat the missing directory to fix the error.
