Inventor General Discussion
Oakcutter
Message 1 of 7 (213 Views)
Using Tables in Assembly
213 Views, 6 Replies
10-03-2012 08:29 AM
I seem to remember from years ago that tables could be used to insert multiple occurences of a single component into an assembly. Is that true or just a dream on my part? Thanks.
*Pro
jletcher
Message 2 of 7 (212 Views)
Re: Using Tables in Assembly
10-03-2012 08:33 AM in reply to: Oakcutter
Are you talking iparts?
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Oakcutter
Message 3 of 7 (211 Views)
10-03-2012 08:34 AM in reply to: jletcher
Yessir, B.L. Oats Mingo Mfg. Inc. Phone: 918-272-1151 Direct Line: 918-212-1214 Fax: 918-212-1214 boats@mingomfg.com
*Pro
jletcher
Message 4 of 7 (195 Views)
10-03-2012 09:32 AM in reply to: Oakcutter
Ok so what did you need? :smileyhappy:
James Letcher
Oakcutter
Message 5 of 7 (189 Views)
10-03-2012 09:52 AM in reply to: jletcher
I have an Inventor assembly that contains an enormous quantity of the same part. Also, there's not much of a pattern so therefore an array does not help much. So I was wondering if I could create a table with x,y,z coordinates of all the insertion points which would drive the insertion process?
*Pro
jletcher
Message 6 of 7 (177 Views)
10-03-2012 10:42 AM in reply to: Oakcutter
Look into work points using excel. This may be a good way. Or look into ilogic to control the work point location. You may also want to look at imates to place them using the work point..
James Letcher
Oakcutter
Message 7 of 7 (169 Views)
10-03-2012 11:02 AM in reply to: jletcher
Thanks, I just looked briefly into work points and I think thats the answer.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
