Inventor Forum
Using Ilogic for detailed drawings
5 REPLIES 5
due303
422 Views, 5 Replies
I would like to know if it is possible using Ilogic to automatic create drawings for parts. I know that it's not always gonna be perfect and I'll have to do some adjustments, but to create the main dimensions, views, etc. Is there a program that I can create using Ilogic that will be able to accomplish that in Inventor 2014?
Thank you very much.
5 REPLIES 5
mdavis22569
in reply to: due303
I'm going to say yes with limits ... You can create an Ilogic to create a drawing sheet with your views desired., however if you use retrieve Dimensions, or have it on for when the views are created then you should have most of it detailed. However it's only as good as the person who detailed it ... if they have poor detailing modeling happens, then the dimension ed views will come out poorly and you'll be redo doing a long of Dim's and turning off others.
Mike Davis
Curtis_Waguespack
in reply to: due303
Hi due303,
There are 13 pages of discussion on this topic at this link, so you migth be able to find something helpful there:
http://forums.autodesk.com/t5/Inventor-Customization/iLogic-Coding-to-Create-Automated-Drawing/m-p/3...
I hope this helps.
Curtis
mrattray
in reply to: due303
Yes, but it's not easy and "your results may vary". Here's an in dpeth discussion on the topic:
Mike (not Matt) Rattray
**** you and your ninja reflexes!
Smiley Happy
