I wanted to know, if it is possible to change the size of a frame member using IAssembly. (created using Frame Generator)
My skeleton is an IPart, and when I create the Assembly I also create a IAssembly to make me able to change the sizes in the assembly.
I wanted to know, is there any way to also change the size of the frame that I choose to put in a certain location. The width and height, not the length.
I have a picture of the spreadsheet I would like to create using IAssembly.
Was I completely clear?
Could someone help me out?
Thank you very much.
Olá!
I think it's better to have one Assembly for each different kind of frame, and place all within the iAssembly (you can use the same skeleton part for every assembly), and then use supress/Unsupress in the iAssembly to chose the rigth option for each situation.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
