Charles,
The Z-axis up has been once provided by a ex-employee of Adesk in some
add-on. I liked it so very much, that I asked the senior programmer of the
maker of Spacemouse wheter he could bring this into the driver. Upon next
release, Adesk implemented this into the core graphic of MDT. Really great,
when you are doing work that should stand upright on screen (like
house/furniture/plants), but maybe not so important when you design
complicated cast/molded parts. You have to try it out in MDT to understand
the difference. And I find it even more important when running the
spacemouse(ball), when you don't have these extra goodis the orbit circle
provides.
The highlight issue is just a whole separate story - if only Adesk could
explain their ideas behind this mess. I could continue the whole evening
about all the negative impact it brings....
I really love many sides and facettes of IV, and am looking forward to the
time where it does me better than MDT.
Have a nice weekend!
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
"Charles Bliss" schrieb im Newsbeitrag
news:3DDFA42E.7020502@cbliss.com...
> I agree with most of your responses. No doubt I missed on the zoom to
> cursor, I just don't remember it being asked for. As a person who uses
> a spaceball, even with laptop, I may be less sensitive to some of the
> zoom stuff and I think I misunderstood what he was asking for with the
> ZAxis rotate.
> The highlighting drives me nuts as well but the real issue (correct me
> if I'm wrong) is the hit on performance. How would you expect a
> preselect mechanism to work? A simple Orbit, pan or zoom turns it off.
> I just wish they would treat a SpaceBall move the same.
> I also wish they would look at some of the interface things others have
> done. Another one I would like to see is a combination of the Right and
> Left button. A couple of other products switch into orbit when they are
> used together. Given the Inventor responds to the up click, it seems
> like it should be possible for it to be programed to look at two down
> clicks and do something different (like orbit).
> Why does Autodesk try to "Reinvent the Wheel"? It is called Inventor
> isn't it?
> Every voice is important!
> Leo Laimer wrote:
> >Charles,
> >I know and respect your opinion.
> >Unfortunately, you give your strong vote to something many others out
there
> >think different about. Please take it as a fact that very many user only
> >monitor this group, without doing any posting, due to lack of time or due
to
> >lack of English knowledge. So it is not true that the opinion of the few
> >great, well educated stars here represent the average of all the
estimated
> >200.000 users of IV.
> >Charles, in some points of Michaels post you didn't quite get the point,
I
> >believe:
> >1. Maintain Z while rotate is a great tool in MDT, and it's missing in
IV.
> >The little dot in the orbit cursor is a first substitute for to get a new
> >rotation point, but nothing more.
> >5. The zoom around cursor location was requested zillions of times here,
now
> >we have it, OK. The other zoom/rotate/pan/zoom all commands every other
> >modeler out there has available on the MMB we will see soon, hopefully.
> >8. This "feature" is the greatest hindrance during everyday work I've
ever
> >seen. Until now, I've not heard of any sense or usefulness of it, nor
seen
> >anybody who liked it. Basically it drops the - already very low - graphic
> >speed of IV by a factor of 10, so really huge files are almost
unworkable.
> >It took several years of developement of the competition until they bult
in
> >this tiny little switch to switch it off.
> >I think, Michael is very right in most of his points - Why does Adesk try
to
> >reinvent the wheel, and not look over the fence and take what's already
fine
> >in other programs (MDT included)?
> >Regards,
> >Leo Laimer
> >news:3DDF7D7F.8080304@cbliss.com...
> >>See comments below:
> >>Michael Levkovitch wrote:
> >>>I am using the MDT and the IV now for 9 years for quite complicated
> >>>mechanical designs (1000 parts and more) For me the ease of user
> >interface
> >>>is very, very, VERY important. So:
> >>>1. Why in IV I cannot rotate (THE MOST FREQUENTLY USED COMMAND!!) as I
> >can
> >>>in MDT using the "Maintain Z" option? In MDT I can rotate freely my big
> >>>machine ALL AROUND while keeping it vertical. In IV it is pain in the
> >ass!!.
> >>>It makes me crazy. I think that today IV is the only one that doesn't
> >have
> >>>it. SW has it also.
> >>The little dot in the middle of the Orbit Cursor can be moved above the
> >>point you want to orbit around then click.
> >>>2. Why IV is the only application (at least I know) that after "Save
As"
> >you
> >>>stay in the "old" file? Normally using "Save As" I want to modify the
new
> >>>file and not the old one.
> >>IV is trying to protect the integrety of your and others assemblies.
> >> When you do a SaveAs, the open file and the saved file are the same.
> >> The difference between them in the filename. If you were working with
> >>a design team and SaveAs changed the name of the part/assembly, it could
> >>have drastic effects on the rest of the design team's assemblies.
> >>>3. Why in IV I cannot copy the dimension features, to and from, one
> >>>dimension to one or many other dimensions?
> >>Not sure what you are asking here; you can reference one or many
> >>dimensions by just clicking on them in responese to the edit dimension
> >>box. You can have older dimensions refer to newer ones and can import
> >>dimensions from other parts / assemblies. This can also be done using
> >>the parameters dialog. In addition, you have full use of placing
> >>formulas in dimensions as well as adding tolerances.
> >>>4. Why in IV I cannot copy hole features from existing one?
> >>Have you tried Copy / Paste? Works for me
> >>>5. Why it took 6 releases to get the Zoom at cursor
> >>Until it appeared, I don't recall anyone ever asking for it.
> >>>6. Why I cannot know the location of the CG relative to a point defined
> >by
> >>>me??
> >>>7. Why, in drawing, I cannot SIMPLY (point and click) select the parts
> >that
> >>>I want to see in drawing. Now documenting the process of buildup of my
> >>>machine based on main assembly is practically impossible.
> >>You need to set your selection filter to Part, then you can select them
> >>in IDWs
> >>>8. Why the cursor always highlights something?
> >>As opposed to AutoCAD / MDT with running osnaps on often trying to snap
> >>to the wrong thing. Inventor is supports both pre and post select and
> >>is attempting to give you visual feedback at all times about what you
> >>will select if you pick something. I believe you are there to create
> >>content, hence the expectation is that you will be picking stuff. If
> >>you don't want it to highlight, hit the orbit button. This will suspend
> >>the highlighting.
> >>>9. Why I cannot osnap directly to whatever I want?
> >>In sketch mode, Inventor is giving you feedback about what it is going
> >>to connect to. This is similar to the osnaps in AutoCAD/MDT. The
> >>difference is that when you place a point, it merges the new point with
> >>existing ones creating a hard connection between the sketch entities.
> >> Watch the cursor closely and you will see that Inventor is actually
> >>telling you what it is going to apply when you click. If it is not what
> >>you want, move a little and perhaps it will give you a different option.
> >> If all you want is an unconstrained point, hold down the Ctrl key and
> >>all but "coincident" will be disabled.
> >>>10. Why in IV I don't have analysis tools?
> >>>In MDT all the above is much, much simpler!! So why to reinvent the
> >wheel?
> >>>AutoDesk, you have it all in house.
> >>As one who used MDT since it was called Designer and wrote thousands of
> >>lines of code enhancing AutoCAD and MDT, I don't share the same
> >>perspective. IMHO Inventor is much easier to use.
> >>>Regards,
> >>>Michael
