Has anyone used the seet metal module to unfold simple curves that will be cut out of wood and clamped down into shape?
I don't know if it's worth trying to, or possible to erase the k_factor for the sake of a few degrees of curvature. I presume the wood will not deform like steel.
Solved by JDMather. Go to Solution.
You can use a neutral k-factor.
