Inventor Forum
Upgrade from Educational Version Problems
5 REPLIES 5
491 Views, 5 Replies
I have recently installed a copy of Autodesk Product Design Suite Ultimate 2013 and am having problems with assemblies in Inventor turning into educational versions. When I was at Purdue University I used the free educational version of Autodesk Inventor. I recently uninstalled Inventor, deleted the autodesk folders in program files, program data, and my documents folders. Then I installed this professional version. Everything works great until i use something from the content center. Once a bolt is placed in the assembly the entire assembly becomes educational when I open it again. Has anyone seen this before? I am at a loss for what to do other than format the harddrive and start again, which I would really like to avoid.
Thanks for the help
Grant
5 REPLIES 5
mrattray
Sounds like your content center has parts that were saved with the educational version.
This is normal behaviour for your assembly to turn into educational.
Think of educational branded parts as a cancer. You have to cut out every last cell or it will grow back and infect everything it touches.
Mike (not Matt) Rattray
JDMather
Were you using the 2013 student version?
If so, you didn't need to uninstall the program - just go to Help>About Autodesk Inventor>Product Information and click Change Serial Number and follow the instructions to Activate the commecial license serial number.
But this sounds like a migration of Content Center files problem.
There is a forum for this type of installation, activation and license problems over here http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24 you might also contact your VAR.
DarrenP
in reply to: JDMather
try this: http://upandready.typepad.com/up_and_ready/2011/10/autocad-family-edu-and-commercial.html
DarrenP
Thanks for all of the help,
Looks like no matter which way I tackle it I am gong to have to uninstall and reinstall Inventor. It takes about the same amount of time to wipe the harddrive and reinstall Windows too. I'm just going to nuke the computer and start again. I can't believe how fast you all responded!
Thanks!
JDMather
Report back if it works.
I have seen documentation that indicates the license information is on a location of the HDD that is not touched even by Format.
But as this sounds like something related to a previous CC I think you will fix the problem with a reformat.
