Inventor Forum
Updating of drawing template
9 REPLIES 9
Message 1 of 10
3961 Views, 9 Replies
I have crated a drawing of the part. Now I must be updating the drawing template. How I can update the drawing templates to old drawings?
-Juha
9 REPLIES 9
Message 2 of 10
ravikmb5
open a new template
save copy as template
save styles to library
open old drawings
click update styles
replace any new templates(if u have different template name)
or use Drawings Resource Transfer Wizard
Which is in Tools
956iEB705A9400613802
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 3 of 10
in reply to: ravikmb5
Now I changed the Title block. How I can update its? I tried to save to the style library but there is not saving anything? So blocks is not in style library?
Message 4 of 10
you can cut and paste the title block between drawings, when pasting it asked if you want to replace the existing (if the title block is the same name) or put a copy in. Then you can just save the new as a template file.
Message 5 of 10
forgot to say, right click and select copy from the drawing resources/title block/[title block name] in the drawing enviroment  as you cant select the title block directly from the drawing  Smiley Happy
Message 6 of 10
As in the post earlier in this thread, use the Drawing resource transfer tool. You can select to copy only the title block to the other target drawings.
Cheers
Message 7 of 10
Thank you so much ! You saved me from a boring and useless work ! 🙂
Message 8 of 10
Skanda_UNI
Is there a possibility to additionally copy the ilogic rules from the template into multiple drawings?
Thank you for your answer.
Message 9 of 10
Mark.Lancaster
in reply to: Skanda_UNI
@Skanda_UNI
This posting is 5 years old you should've creating your own posting..  Smiley Wink
But to answer your question..  Yes by using the Inventor Code Injector.
Mark Lancaster
Message 10 of 10
mcgyvr
@Skanda_UNI
If you have 2018 Update 1 (2018.1) you can also use an external rule and set a trigger from the event triggers to apply to "all drawings"
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-B14A47F4-81D2-4627-A973-2BC7F790DF89
