Many duplicate occurrences shown in browser of IPN's following assembly demote/promote
Create New dialog does not remember the size and order of column in details view
Mass property is not available after migration
Min and Max values for Hole patching are not stored
View remains raster after selecting Precise view
iFeature insert dialog will show "Create Package" instead of the description of the iFeature
Copying a material in the category will corrupt that material from the library
Unable to change icon of existing custom category in Content Center Library
Adding a material will flag existing file as out of date and unnecessarily replace/update appearances
Weldment iAssemblies still looking for the obsolete "Use as Weldment Material" setting
Highlight effect when mouse hover on geometry is not as good as full mode when create Dimension/Baseline/Ordinate annotation in Raster View
GraphicsNode.RenderStyle has no effect on the graphics entity
The translator addin imports the DWG into sketch with wrong units if custom units specified
Legacy Section View displays incorrect line
Title block incorrectly displayed on Zoom when multiple files opened
Decreased performance when selecting all assets
Decreased performance when select Derive menu Other Tab
Slow shut down of InventorViewCompute.exe even after Inventor main window closes
Unexpected exit when make all views raster and make all views precise
Unexpected exit when switching to Full from Express mode
Unexpected exit when click adjust with customized project setting
Unexpected exit when rotating large assembly
Unexpected exit when dragging materials in user library
Unexpected exit when Load Express
Unexpected exit when starting Inventor from Factory Design Suite
Unexpected exit due to Non-transacted AddTriangleGraphics
download here: Update 1 for Inventor 2014
DarrenP
Solved by DarrenP. Go to Solution.
link fixed
DarrenP
I think I'm glad we held off making the switch.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hurray they fixed the new dialog column stuff that I reported for 2013. Sadly I doubt we'll update to 2014 until the first service pack.
On another note either more people have held off switching to 2014 compared to when 2013 came out or there are less issues. I haven't noticed near as many threads about 2014 issues yet.
There are no bugs, just issues that are fixed with this Update
