Hi:
I am getting unresolved links to a couple iParts in an assmebly. My iParts and assembly are in different folders that are under configuration management. This means that I must check the files in and out of the configuration management tool in order to modify them. From a Windows perspection, all the tool does is change the read only attribute on the file. When the files are read only, the links to the iParts don't work. When the files are not read only the links work. These are not the only files that are set up under configuration management, but they are the only ones that cause broken links in an assembly. Any ideas?
