I had the same problem. First right-click on your view and select "edit view"; go to "display options" tab, un-select "hatching", hit "ok". All your hatching will dissappear at this point. Next right-click your view again, select "edit view", go to "display options" and re-select "hatching". Click "ok" and all default hatching for the entire view will come back. (BTW working with Inventor 2014 Pro).
Hope this helps;
Voytek.
Apparently that does work. It seems the part just has no hatching. It is an o-ring and due to it's small size no hatching is visible. The other o-rings in the view all have at least one hatch line which I was editing to give them more so you could see them better.
It may not be that convinient, but alter the scale of your detail until you can see hatch lines... then alter the hatch? If they're still linked I think it should work
This is a big issue that Autodesk seem to have completely overlooked though. Hatching is terrible in AutoCAD too, maybe they do it on purpose
