I'm unfolding a 30x40x2 mm square tube for tube laser. The tube is imported from STEP format.
The flat pattern is 1,5 mm too narrow - even when I increase the K-factor to 1,0.
Is there any work around to get a wider flat pattern.
okdok
IV 2010
HP-Z200 Pentium 3,3 GHz
12 GB ram AtiFirePro V-4800
Windows 7-64 Pro
Solved by okdok. Go to Solution.
How wide is it?
Attach the file here.
How are you arriving at the figure 134,85?
Something doesn't make sense here.
The part will stretch as it is bent - so I would actually expect a smaller number - not a larger number.
Are they calculating the (kerf - not sure what you would call it with laser cutting) the removed material from stock, or the finished flat size?
Who is doing the folding - perhape the best solution is to simply give them the finished dimensions for the part and let them calculate as they see fit. All you care about is the finished part dimensions.
I don't know why the tube laser needs that size, but I have to deliver - one way ore the other. The problem seams to be that with the imported part, the only available parameter is the K-factor, otherwise I cold adjust the coner radie. I only hoped there would be something I had missed. I'll unfold in Inventor and then stretss a little further in AutoCad.
Thank you for your time.
okdok
You could run Feature Recognition addin - http://labs.autodesk.com
or
remodel this simple part as a native Inventor part.
