I am trying to unfold a part created from a derived assembly like I usually do… why in the world will it not unfold, and show a preview of the unfolded in the other direction??
At first all was working… until I added a part (see the circled item in picture), and I don’t have any problem usually!
Sophie
Check to make sure that you have set the proper thickness in the Sheet-Metal settings. This must match the thickness of the derived part.
Thanks for all your helps.
Can't send only my part cause it is made from a dirived assembly.
Yes i am trying to combine multiple flat pieces into one press braked part.
Found out a temporary solution... (see picture) had to cut out into the dirived assembly so the un fold would work,
But don't know why.
Still, thanks all your helps!
Sophie
