Hi All,
first of all i'm sorry this is very basic question that i'm asking because i could not find the answer.
i want to draw spiral stair and obviously after that i want to unfold the stringer, is it possible with inventor??
i have created cruved stringer with sweep command but inventor does not develop the flat of that,
and as i know this is very simple with solidworks so many tutorials are availble on youtube but i could not found how to do this with inventor. (for you refrence https://www.youtube.com/watch?v=F7bcYwxUFdQ
thanks all of you in advance.
Solved by JDMather. Go to Solution.
Hi ayub.shahid,
Attached is a quick example file that uses the Helical Curve tool of the 3D Sketch environment to do this.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-225C2059-13B8-4F44-8352-2F1FE16221B9
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E2E72765-3BF6-43CD-9983-BC40A79E9D43
I hope this helps.
Curtis
What version of Inventor are you using?
Attached is a somewhat easier technique (in my opinion).
i'm using version 2015, thanks JDMather this is really what i was looking but can you explain little bit in depth how you have done it.
i'm trying but i'm getting error could you please help me. i attached some screenshots.
thanks agian.
