I made a drawing, but after using ilogic (ilogic is in drawing,assembly, part) in it, drawing view of a particular part is coming in hidden line, other are shaded as u can see in image.
Drawing view is associative, all edges shown, level of detail is master, view style is Hidden Line Removal with Shaded
Computer Config:
Inventor 2013
Intel Xeon CPU
2.67 GHZ
8 Gb ram
Windows 7 64 bit
no attached image
I would suggest posting an image of what you are seeing as well as the code for the iLogic rule you are using.
It is possible that your issue lies within your rule.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Guessing here without the image, but it sounds like the BOM Structure of the offending part might be Reference?
