I would guess new acads will read SAT 7 since they are built on new ASM
kernel which was founded on ACIS 7. But beyond 7 it wont be called ACIS
(SAT) as adesks licencing of acis stopped at R7. I have no idea if there
will be a new exchange format developed for ASM as it moves forward. Imagine
if autodesk set a standard for fully featured exchange.
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Jim Strenk" wrote in message
news:CF3C4E97A5B4514FB9BCBCCA4E47D96C@in.WebX.maYIadrTaRb...
> By "turning it down a notch" aka a reverse Emeril Lagasse, did the trick.
I
> would imagine that future versions of AutoCAD will incorporate a newer
> version of the ACIS Kernel, no?
> Thanks Quinn and Darvinv for your replies!
> "Quinn Zander" wrote in message
> news:A4FAE1685B26FBFD5A4CE8389E384CED@in.WebX.maYIadrTaRb...
> > Jim,
> > Once you specify the filename, hit the options button in the save dialog
> > and bump the SAT version down to 6.0.
> > QBZ
