Hi everyone,
I have been using this forum for a while and it has already been a huge help so thank you!
The problem I'm now having is this:
I am engraving a company logo on to the outside of a round tube with a custom font. There are two boxes of text that I am engraving. The first box works just fine with the "Emboss" tool. The second line works fine when the "% Stretch" parameter in the text edit window is left at 100%. When I change the "% Stretch" to 85%, I get the "Self-intersecting loop found in this profile" error message. I get this error message when I try stretching it to 115% as well. I changed the font to a standard font and I was able to emboss the text no matter the "% Stretch" value.
The bottom line is Inventor will not emboss text that has a custom font and a modified stretch percentage. Does anyone know how to fix this? This line of text must be stretched to match the company logo.
Thanks in advance!
Sam
Solved by mcgyvr. Go to Solution.
That problem has come up before with certain fonts..
I have solved issues like that by actually drawing the font with lines/arcs,etc..
yeah its a pain but do it once and its done..
I was hoping to avoid that but if that's how it's done then that's how it's done. Thanks mcgyvr! Kudos given and accepted as solution.
Sam
