I have created a multi-value parameter in a part and exported it. I then linked it in the assembly but I am unable to edit it. I tried using iLogic but it also does not alter the part. Please see the attached 3 jpegs. I'm not sure what I'm doing wrong. I have been combing the discussion boards but I am unable to find an answer to my problem. I'm certain that it just has to do with me not correctly understanding ilogic and parameters. This is my first attempt at using them outside the tutorials.
Solved by johnsonshiue. Go to Solution.
Thank you for continued attention and patience. I guess I don't understand the difference between an ipart member and an ipart factory. I don't understand what to do when I right click on the ipart in the assembly browser and then select replace components. From here I can see my part - it's just a ".ipt" file - there's no indication whether it's a member or factory. It is already in the assembly so clicking on the ipt would just replace it with itself (please see attached screenshot).
Hi! After clicking the iPart factory file in the dialog, you should get prompted to select which member to be replaced. Did you see the iPart Placement dialog?
Thanks!
I figured out what I was doing wrong. I had to right click on the iparts in the part file and select "generate part" before the parts became available. Then I did what you said and went to the assembly and swapped out the iparts for the newly generated part. Then I was able to create an iassembly and use the information from the tutorial you sent me in order to generate the assemblies. It's still not quite right - I have to play around with my constraints to make it work but I'm on the right track! Thanks so much for your help!!!!
Dear sir,
i am trying to do same thing.
i have created parameter in ipt. which is called in iam. and I want to change this parameter in iam so my part will update and so as assembly. I have created iparts as well.
but for some parameter there is no standard value, I have to give input manually.
Which will be changing every time. So i am creating a form to enter input value manually.
But the problem here is iLogic rule is not able to change ipart parameter in iam. as same case above. Please guide suitable solution.
Thank You.
Hi! Please see my reply to the other thread.
Please avoid having duplicate threads. It can be confusing.
Many thanks!
