Inventor Forum
UI Ribbon buttons -- text is cut off
11 REPLIES 11
Message 1 of 12
1982 Views, 11 Replies
I have just installed Inventor 2013.  How can I fix the UI Ribbon cutting off button text?  I have attached a photo demonstrating the problem.  I cropped the screen shot to only show the ribbon to cut down on excessive image size.
Gordon
Tags (4)
11 REPLIES 11
Message 2 of 12
JDMather
Click here 3 times and see if that helps
Is your video card/driver up-to-date?
Message 3 of 12
in reply to: JDMather
I tried that and cycled through hiding the ribbon until it showed up again.  It didn't change anything.  The words are still clipped and the bottom of the text is still cut off.
Yes, my video drivers are up to date.
Message 4 of 12
JDMather
Have you installed Service Pack 1 and rebooted the computer?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20442029&linkID=9242019
Message 5 of 12
The installer gave me the option to include service pack 1.  Is there an automatic update tool or any other way to determine if it is installed?
I see update 2 listed.  Should I install that instead? http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19656800&linkID=9242019
Message 6 of 12
I just reinstalled SP1 and verified that the "About Autodesk Inventor Professional" windows shows that I have SP1 installed.  I restarted my computer with no luck.
Message 7 of 12
blair
Are use using "recommended" monitor/screen resolution and your text size is set to standard on your system screen/display settings.
Delta Tau Chi ΔΤΧ
Message 8 of 12
in reply to: blair
Well, my resolution is 2560x1600 on a 30" Panel.  I have Windows font size set to the preset of large.
I would assume that a Windows 7 font size preset would be "recommended" right?
However, it seems like dynamic button sizes would be a pretty essential feature.  I don't see any options to adjust font sizes in preferences either.
Message 9 of 12
blair
Not sure what the native resolution for your monitor is, but try setting the text size to (Smaller - 100% (default)) on your system. If you have set it to larger you could be cutting off part of the Ribbon.
Delta Tau Chi ΔΤΧ
Message 10 of 12
in reply to: blair
The native resolution on my panel is 2560x1600.
The smaller preset is too small for 2560x1600 resolution.  There are twice as many pixels on the screen compared to 1080p.
I will check to see if that makes the ribbon text work, but that won't fix my issue because then I won't be able to read anything else on my computer.  Maybe this should be marked as a bug?  Is there a public bug tracker?
Message 11 of 12
blair
If an Autodesk employee happens to read this post, it may get picked up as a bug or if you are on subscription and log a support call it will get picked up as a bug.
I remember seeing issues back in release 10 or 11 dealing with laptops and wide-screen res problems with menus and context boxes.
Delta Tau Chi ΔΤΧ
Message 12 of 12
_KarlH
Thread necro. Been wondering about this same issue recently - found that it's caused by this Windows Font Scale setting - most annoying cause I prefer a larger font for my other apps.
