Inventor General Discussion
Active Member
gordon
Message 1 of 11 (512 Views)
UI Ribbon buttons -- text is cut off
512 Views, 10 Replies
09-23-2012 01:47 PM
I have just installed Inventor 2013.  How can I fix the UI Ribbon cutting off button text?  I have attached a photo demonstrating the problem.  I cropped the screen shot to only show the ribbon to cut down on excessive image size.
Gordon
JDMather
Message 2 of 11 (506 Views)
Re: UI Ribbon buttons -- text is cut off
09-23-2012 02:12 PM in reply to: gordon
Click here 3 times and see if that helps
Is your video card/driver up-to-date?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
gordon
Message 3 of 11 (501 Views)
09-23-2012 02:17 PM in reply to: JDMather
I tried that and cycled through hiding the ribbon until it showed up again.  It didn't change anything.  The words are still clipped and the bottom of the text is still cut off.
Yes, my video drivers are up to date.
JDMather
Message 4 of 11 (497 Views)
09-23-2012 02:22 PM in reply to: gordon
Have you installed Service Pack 1 and rebooted the computer?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20442029&linkID=9242019
Active Member
gordon
Message 5 of 11 (493 Views)
09-23-2012 02:24 PM in reply to: JDMather
The installer gave me the option to include service pack 1.  Is there an automatic update tool or any other way to determine if it is installed?
I see update 2 listed.  Should I install that instead? http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19656800&linkID=9242019
Active Member
gordon
Message 6 of 11 (487 Views)
09-23-2012 02:37 PM in reply to: gordon
I just reinstalled SP1 and verified that the "About Autodesk Inventor Professional" windows shows that I have SP1 installed.  I restarted my computer with no luck.
blair
Message 7 of 11 (472 Views)
09-23-2012 03:44 PM in reply to: gordon
Are use using "recommended" monitor/screen resolution and your text size is set to standard on your system screen/display settings.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Member
gordon
Message 8 of 11 (427 Views)
09-24-2012 08:38 AM in reply to: blair
Well, my resolution is 2560x1600 on a 30" Panel.  I have Windows font size set to the preset of large.
I would assume that a Windows 7 font size preset would be "recommended" right?
However, it seems like dynamic button sizes would be a pretty essential feature.  I don't see any options to adjust font sizes in preferences either.
blair
Message 9 of 11 (421 Views)
09-24-2012 09:06 AM in reply to: gordon
Not sure what the native resolution for your monitor is, but try setting the text size to (Smaller - 100% (default)) on your system. If you have set it to larger you could be cutting off part of the Ribbon.
Win7-64
Active Member
gordon
Message 10 of 11 (418 Views)
09-24-2012 09:14 AM in reply to: blair
The native resolution on my panel is 2560x1600.
The smaller preset is too small for 2560x1600 resolution.  There are twice as many pixels on the screen compared to 1080p.
I will check to see if that makes the ribbon text work, but that won't fix my issue because then I won't be able to read anything else on my computer.  Maybe this should be marked as a bug?  Is there a public bug tracker?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
