See attached screenshot.
Somehow my top level assembly shows the UCS triads for hundreads of my parts (but not all of them). I know I didn't turn the visibility of all these UCS triads on manually. Now I cannot get them to turn off.
When I toggle the visibility status of a few and save the file they come back when the file is reopened.
Note, they are NOT visibile in their respective part files, just in my top level assembly.
Please help me turn these off.
Have you tried toggling the visibility here?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you for the quick reply. I am currently turning them off using the Object Visibility but this is only a temporary fix. I need a way to toggle their visibility so I don't have to jack around with the file everytime I open it.
Could it be that the parts in question have multiple view representations (one with the UCS visible, one with it invisible), and your assembly is referencing the wrong one?
You might want to try checking one of the parts that have the issue, and inspecting the View Representations to see if any of them leave the UCS visible. Then check the assembly to see if it is referencing that representation.
If that is the case, you could fix it by either associating the assembly to the part view rep where you hid the UCS, or by hiding the UCS in the other view reps.
Rusty
Thank you all for the help. I am seeing the same thing as LT. Rusty. It's not just the UCS triads, it's a single random plane that won't shut off and some work points.
I am pretty sure it is not a view rep since I have only made two Level of Detail reps (ever) and the UCS triads are showing up on equipment not related to them.
It is frustrating to say the least.
Cbuckthree
You could try the following steps. File>Options>Display>3D Navigation> Origin 3D Indicator and uncheck both check boxes. Hope this helps!
