Inventor Forum
Tubular trouble
11 REPLIES 11
Message 1 of 12
287 Views, 11 Replies
Tubular trouble
Is it possible to make a from-to tubular extrusion from one tubular to another hitting the outside of the tubes?
There’s the minimum solution thingy but it only works in one direction.
I’m doing a lot of tube work (Off-shore constructions) so any help would be much appreciated.
Best regards
Flemming
LICengineering
DK Denmark
11 REPLIES 11
Message 2 of 12
I am not sure I understand where you are having trouble. I am posting a
simple example to customer files where a tube hits two others, and uses
Minimum solution on both.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"frm" wrote in message
news:f18c1d2.-1@WebX.maYIadrTaRb...
> There's the minimum solution thingy but it only works in one
direction.
> I'm doing a lot of tube work (Off-shore constructions) so any help
> Best regards
> Flemming
> LICengineering
> DK Denmark
Message 3 of 12
Hello Kent
Thank’s for your suggestion.
I was trying to make it work in one operation, see attachment in CF, but maybe that’s not possible?
Regards
Flemming
Message 4 of 12
I had never tried doing it like that before.
I have no idea if it is as designed or a fluke or ?? but on your part I edited the feature
and on the More tab I hit the other alternate solution button, and now both ends appear to
be to the minimum solution.
The odd thing is the next time you edit the feature the alternate solution is back to the
original button and if you ok out without making any changes it reverts to going to the
outside on one side. BTW I don't have R6 here so I am using R7 to do this.
Kent
Assistant Moderator
"frm" wrote in message news:f18c1d2.1@WebX.maYIadrTaRb...
> Hello Kent
> Thank's for your suggestion.
> I was trying to make it work in one operation, see attachment in CF, but maybe that's
not possible?
> Regards
> Flemming
Message 5 of 12
Morning Kent
I tried editing the tubes and they behave as you said. Weird.
Well maybe I just have to do it the other way. But it’s annoying when you are working on a 60 to 100 meter jacket with a lot of cross bracing. There’s much scrollwork to do in the browser panel 🙂
This might be something for the wish list. “Minimum solution both directions”.
Thank’s again
Regards
Flemming
Message 6 of 12
This is a bug IMO whatever.
I am afraid I am so rusty on IV that I have even forgot how I made a tubular
model similar to your work albeit on a smaller scale.
But for now you will have to accept a short cut to what ever my method was,
flip normal work plane 1.
Perhaps someone can send this one to Autodesk?
Laurence,
Power is nothing without Control
"frm" wrote in message news:f18c1d2.3@WebX.maYIadrTaRb...
> Morning Kent
> Well maybe I just have to do it the other way. But it's annoying when you
are working on a 60 to 100 meter jacket with a lot of cross bracing. There's
> This might be something for the wish list. "Minimum solution both
directions".
> Thank's again
> Regards
> Flemming
Message 7 of 12
Try this:
1) Start new part (middlepipe.ipt)
2) Derive Master.ipt
3) Extrude sketch2 as a surface (both outer pipes)
4) Extrude sketch1 to pipe on left (surface), using minimum solution
5) Extrude sketch1 again to pipe on right (surface), using minimum solution
"Laurence Yeandle" wrote
in message news:29D431FA91E33E1D72448CF37E4E3588@in.WebX.maYIadrTaRb...
tubular
was,
> Laurence,
> > Morning Kent
you
There's
> directions".
> > Thank's again
> > Regards
> > Flemming
Message 8 of 12
I have placed an example in IVCF
"Teun Ham" schreef in bericht
news:1B79D27A2D9590B7E1986716D0414BE8@in.WebX.maYIadrTaRb...
> Try this:
solution
> tubular
> was,
> > Laurence,
> > > Morning Kent
> you
> There's
> > directions".
> > > Thank's again
> > > Regards
> > > Flemming
Message 9 of 12
Teun
I posted a similar solution on 09/21 but the point is valid that it should be able to do
minimum solution both directions.
Kent
Assistant Moderator
"Teun Ham" wrote in message
news:650A49868D409BB401E86C2F2368BBDC@in.WebX.maYIadrTaRb...
> > Try this:
> solution
Message 10 of 12
Yes, I agree. And it is me who posted a similar solution, not you 😄
I only wanted to show that you can achief the same thing with only 1 derived
master sketch (or skeleton part as I would call it).
Deriving too many parts can cause problems (just like linking two different
cells of the same excel spreadsheets to one part).
I try to stick to only one derived component per part.
"Kent Keller" schreef in bericht
news:798E9B01A6DD5841965F33B5E661F5B8@in.WebX.maYIadrTaRb...
> Teun
be able to do
> Kent
> Assistant Moderator
> > > Try this:
> > solution
Message 11 of 12
I agree there was really no reason to derive multiple files in that case, but I have files
where you can't do that easily. For example bent pipes that follow 3dpaths.
I have never seen any problems deriving multiple files into one before. I do it semi
regularly.
Kent
Assistant Moderator
Message 12 of 12
It seems to make no difference as to start direction on the original attempt
at a minimum solution.
Even flipping the plane prior to extrusion has no effect, so only flipping
plane (simple solution) or editing the direction in extrusion kick starts
the correct minimum solution.
That said it is defect IMO.
Whether master sketch or simple in line part creation you are only wanting a
minimum one extrusion in both cases to keep it simple.
Laurence,
"Kent Keller" wrote in message
> Teun
be able to do
