I'm fairly new to Inventor, but I'm usually a quick study. Unfortunately, one thing that has me lost is running tubing from point A to point B when the connection points are not in line with each other. Our company doesnt run enough hose & tubing to justify the expense of the Tube & Pipe Environment, so I'm trying to run them manually. Attached is an image of one of the short, easier runs I have to do (from hose fitting to hose fitting, marked by yellow arrows). If I can get some help with this, I should be able to apply the principals to more involved runs.I very much appreciate any help anyone can provide!!
Thank you much!!
Joseph (jritchie@ozarkfluidpower.com)
Solved by cwhetten. Go to Solution.
Solved by bob_holland. Go to Solution.
Joseph,
Welcome to the forums.
Here is a tutorial on how to Create Inventor 3D Sweeps from a 3D Spline:
http://www.trainingtutorial.com/TAT10.htm
Good luck.
Wow! With the information both of you provided, I was able to drop a perfectly shaped/sized hose in my assembly in only a few minutes on my first try! Not like the 75 abhorations I placed in my own attempts previous! Thank you very much!!
Joseph
u don't need to create a sweep object when u r in d pipe n tube enviroment. just create ur own pipe and tube style, activate it and use it for ur own project.
Cameron,
Would you happen to have a video on how this is done? I'm a pretty frustrated Inventor user. I know everyone says the same thing but I know I could have done this simple task in SolidWorks in my sleep in about 10 seconds.
Thank you.
Hi @Anonymous
Sorry I didn't see your post until today. I will work up a video to illustrate the process.
Cameron Whetten
Inventor 2014
I'm glad you got it to work Bob.
In case you still want to take a look at the video I made, here you go:
https://screencast.autodesk.com/main/details/6239cf4a-be38-4a07-a0b7-35d8f4437604
Cameron Whetten
Inventor 2014
